I have a Myford Super Seven and a Myford ML10, just made a collet holder for ER collets, really made it for the ML10, both lathes have identical nose thread and registar, I have carefully checked the registar on both. I bored the taper for the collet on the ML10 whilst it was screwed on to the mandrel so on checking obviously zero run out, thought lets see how it is on the Super seven and to my suprise 4 thou total run out of the tapered bore, how can this be ?
Both mandrels are running absolutely true (I checked them) the register in the holder I made is spot on, I'm baffled. David
