I have my Elliot surface grinder stripped down, today I took the top off the hydraulic tank on the end of the suction pipe there is a brass gauze strainer, it appears to be made with the gauze just rolled up and the ends soldered on, it is very fine gauze.How do I get it clean? Its soaking in kerosene at the moment, I am not sure what was in the oil tank with the oil it looked milky like coolant but was also very thick, coagulated even, maybe slightly acidic all the copper and brass pipework is as clean and shiny as new stuff.
Will
Will
