roller bearings
  • shane
    Junior Member
    • Nov 2003
    • 7
    roller bearings
    Anyone know of any good web sites to buy roller bearings for a 3/4 inch shaft? I live in a small town and dont have much access to big stores they will be used in making a mud motor for duck hunting Thanks Shane
  • Forrest Addy
    • Oct 2002
    • 5792
    #2
    What's a mud motor? Never heard the term before.
    3/4" roller bearings? Izzat needle roller bearings? Taper roller bearings? Will ball bearings do? Or Bronze? Plastic bearings will work under water. What kinda loads just out of curiosity?
    Here's a few places:
    • shane
      Junior Member
      • Nov 2003
      • 7
      #3
      A mud motor is a motor which is used on a jon boat for duck hunting it runs in shallow water and mud brand name go devil. needle roller bearing are what i am looking for for a 3/4 inch shaft and a one inch housing for the shaft. Thanks shane
      • Evan
        • May 2003
        • 41977
        #4
        "and mud brand name go devil."
        What does that mean?
        • winchman
          • Aug 2003
          • 4030
          #5
          • Joel
            • Jun 2001
            • 3229
            #6
            Punctuation.
            I am guessing "water and mud. Brand name: Go Devil"
            • wierdscience
              • Jan 2003
              • 22088
              #7
              BTDT,but I used a 1-1/2"x 1" npt pipe bell reducer for the top end of the tube,this way I was able to bore out the reducer for a Sealmaster ER-12 bearing,it has an O.D. of I believe 1.750" and an I.D. of .750" with two setscrews to lock it to the shaft.
              On the bottom I used a rubber strut bearing with a s/s wear sleeve on the shaft.
              If you really want fun scale it up to a Subaru flat six and a 12" 6/6 prop WEEEEEEEEEEE........!
              • shane
                Junior Member
                • Nov 2003
                • 7
                #8
                Could you send pics of yours? I have a fourteen horse right now.
                • wierdscience
                  • Jan 2003
                  • 22088
                  #9
                  Do you mean actual bearing numbers or the design itself?
                  If it the bearing numbers you want no problem,if its the design,all I did was scale one off a picture my customer printed off the net,most of the engines you see now have a square bolt pattern around the shaft,all it really takes is a shaft support tube with a bearing on each end.
                  I cheated by using pipe fittings for part of the one I built,its been going for two years now without a hitch so knock on wood it works.
