OSG die sets.... group buy
$837, wow.
Buy a used self opening die head off ebay, Geometric, etc, maybe $250 max.
Use the rest of the almost $600 to buy chasers in various sizes as needed.
Then you'll really have something.
Those small "threading" dies are not much good for anything, even OSG brand.
Actually, that's a bit too harsh a statement, they are good for repairing damaged threads.
A major drawback with the small dies is they are so thin.
You have a lead-in on one side where the cutting happens. Following that you have a few turns of thread in the die to guide it to maintain the correct pitch. Those following turns of thread also have to act to force the die to feed forward down the blank as the die is rotated (or as the work is rotated).
The feeding forward causes the die to "shave" the thread flanks as it progresses down the blank.
Kind of hard to describe, but a well known problem in the threading business.
This problem can be eliminated by mounting the die in a holder on the lathe carriage. Set the threading gears of the lathe for the die's thread pitch and power feed the die down the blank.
Even with the lathe power feeding method, you still have the problem that only the first thread or so in the die is doing the cutting leading to short die life from dulling.
As I said previously, $800 is a lot of money to spend for tooling that doesn't do much of a job under the best of circumstances.
Originally posted by DREven with the lathe power feeding method, you still have the problem that only the first thread or so in the die is doing the cutting leading to short die life from dulling.
I've always started the die by feeding the work piece into the flared out side which only cuts partial threads. In which case it is the last couple of threads that do most of the cutting, at least to full depth. Am I doing it wrong?
Regardless, I always find die threading difficult, especially getting it started. Are you supposed to turn the work down to a taper on the end?Lynn (Huntsville, AL)
markj: I made much the same point as you as an aside in a recent thread. I suspect the fault is in my dieholder. I know mine may be a bit ropey. I certainly recognise what you're talking about. I get it all the time with threads of any length.Richard - SW London, UK, EU.
