View Full Version : Anybody using DMM-Tech AC servos ?
KiloBravo
10-26-2010, 01:04 AM
http://www.dmm-tech.com/ $1,681 (USD) for 4 axis kit.
Peak 7.2Nm(1015 OZ-In) high torque AC servo motor, 4 Axis CNC kit
for MACH3
- 4 x Peak 7.2Nm(1015 Oz-In), rated 2.9Nm(408 Oz-In), Peak power 900W, AC servo motors
- 4 x Dyn2-H AC servo drives for very smooth, quiet, high efficient driving.
- 1 x DMB4250-8B breakout board, fully buffered Opto-isolated I/O, isolated PWM analog output
for spindle speed control,and charge pump. Hardware generated X secondary X' for CNC Gantry with
jump selectable motor turning direction.
- 1 x 6ft DB25 parallel port cable
- 1 x 6ft USB cable
- 3 x 120 or 220Vac input, 350w,+48Vdc, 7.3A output DC power supply
- 4 x 1ft cables between breakout board and drives
- 4 x 10ft differential signal encoder extension cable, 25ft cable available too
- 3 x inductive, non contact , LED indicated proximity Home/Limit Switches
- 1 x Emergency STOP Switch
- Necessary Cables, DMM software for tune up servo
macona
10-26-2010, 08:47 PM
I would pick up one of the kits of used Yaskawas or Mitsubishis over those. He lists peak powers instead of continuos powers. A Yaskawa at 900w will blow those out of the water. Especially with each being driven with a 350w power supply. Cant get 900 watts out of 350.
KiloBravo
10-26-2010, 10:35 PM
Yes, funny thing the day I got my Boss IV I saw a 3-axis Yaskawa 750W drive "kit" on Ebay. I checked a few hours later and it was gone :mad:
Have not seen one since !!! Patience is a virtue so I guess I will wait for another one to pop up :cool:
adamd
10-27-2010, 12:35 AM
This guy have good prices on teco ac servos. I have had good luck with teco vfd. I don't have any affiliation with them just saw that they had good prices.
http://www.machmotion.com
macona
10-27-2010, 01:08 AM
Wow, I didnt know Teco was making servos. Pretty amazing, a 750w motor/drive combo for $630.
They kind of look like a Yaskawa knock off.
