View Full Version : My turn for a tool gloat
Hawkeye
11-11-2010, 11:35 PM
I got some good stuff last weekend at an auction. Spent a total of $2395 on a Hembrug lathe, Walker Turner 14" wood and metal band saw, a homemade Arbor press, Small drill press, Toolpost grinder, and a ton of tooling.
As I sort through it all, I'll be posting some "what is this" post.
Enjoy the pics.
Rick
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0420.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0424.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0423.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0422.jpg
I downloaded a manual for the Hembrug DR1 pretty close but not exactly the same. This control is differnent than the manual. I think it's Low speed to the left, High speed to the right, Up for forward Down for reverse. If anyone knows please reply!!
Hawkeye
11-11-2010, 11:37 PM
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0413.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0416.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0418.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0417.jpg
Hawkeye
11-11-2010, 11:42 PM
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0431.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0430.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0429.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0428.jpg
Dr Stan
11-11-2010, 11:44 PM
Your WT bandsaw appears to be virtually identical to my Rockwell wood/metal saw. In both cases they are good machines.
Not familiar with a Hembrug lathe, but it looks solid. Where & when was it built?
BTW, I think you did well for the $.
Hawkeye
11-11-2010, 11:46 PM
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0427.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0426.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0425.jpg
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0414.jpg
Hawkeye
11-11-2010, 11:48 PM
http://i1186.photobucket.com/albums/z376/hawkeye222/Auction%205%20Nov%202010/Auction_0415.jpg
Hawkeye
11-11-2010, 11:55 PM
Dr Stan --
Hembrug lathes were made in Holland. I haven't found the manufacture date but I think it's 1950's or earlier.
Here's a link with a better description: http://www.lathes.co.uk/hembrug/
Mine 10.5" swing and 30" Center to Center.
fishfrnzy
11-11-2010, 11:58 PM
This beats my auction gloat! Looks like you got more than your money's worth, and then some more after that. Good for you , lots of nice bits and tools too.
Were you the only one at the auction?
Ken_Shea
11-12-2010, 12:09 AM
Nice bunch of equipment Hawkeye, you weren't exaggerating when you said a ton of tooling.
Hawkeye
11-12-2010, 12:11 AM
fishfrnzy,
If I was the only one at the auction, I would of had a lot more to show for it...
The Auction started @ 9:00 Am . I bought the lathe and tooling (they kept it all together!!! sold as one item) @ about 9:00 PM. and the Bandsaw at 10:00 pm.
Just need to be willing to wait!
davidwdyer
11-12-2010, 03:59 AM
Wow! That's a ton of tooling etc. You sure did get your money's worth. Congrats.
whitis
11-12-2010, 04:17 AM
I am amused by the lathe with the controls labeled in Klingon. :) An American acquaintance remarked after spending a year in the Netherlands: "Dutch is the language Klingons speak". Rather fitting, then, that the first full length Klingon opera was performed there. Of course, the French might make a similar comment about English.
You don't really need a translator for the speeds/directions - the lathe will tell you. Now, trying to figure out the threading on a Monarch 10EE if you couldn't read the controlls, that would be a bit of a challenge (there are an unusual number of knobs and levers to be set). My old lathe, incidentally, has no markings on any of the controls.
You sure got a boatload of tooling.
PixMan
11-12-2010, 06:11 AM
That is one fantastic haul! Looks like a high-quality lathe and the tooling is what really makes it a bargain. You could spend years hunting around and never come up with a collection like that for that kind of money.
Congrats, great buy.
vpt
11-12-2010, 07:04 AM
That is an atlas 10-12" milling attachment. Common to be retrofitted to other lathes. Ebay value $200-250.
Nice collection of tools and machines! You like the arbor press, they are very handy!
Hawkeye
11-12-2010, 09:50 AM
Whitis,
From online translators,I've confirmed that LAAG = Low, and HOOG = High,
Still not sure what the 'L' and 'R' stand for.
Glad you mentioned threading... I don't have a threading dial, How do you cut threads without one? Anyone have one laying around?
Dr Stan
11-12-2010, 10:30 AM
Two guesses on the "L" and "R". Probably either forward and reverse, or for two speeds within the high and low ranges.
A threading dial should not be too difficult to modify/construct. What is the TPI of the lead screw? If it is the same as a SB I'd check with Little Machine Shop for the SB thread dial and use it. I'd also check to see if a Logan thread dial would fit.
The other option is to engage the half-nuts and reverse the lathe at the end of each pass never disengaging them until you are finished. Just like metric threading on a lathe with an imperial lead screw. A bit of a PITA but it works.
DFMiller
11-12-2010, 10:31 AM
Would L and R be left and right?
Nice haul.
Have fun
Alistair Hosie
11-12-2010, 10:32 AM
Old show off :D well done son I am proud of you have years of fun from your new tools lathe and tooling etc.Alistair
boslab
11-12-2010, 02:31 PM
good deal, difficult to explain to her indoors, no threading dial, a bit of chalk works!
regards
mark
Hawkeye
11-15-2010, 01:03 AM
Bobslad,
Can you explain how to use a piece of chalk for threading?
thanks,
Rick
