View Full Version : Clamp set for 4 inch RT
jfsmith
12-15-2003, 02:41 AM
I have a LMS Model 1627 4" R/T, what size clamp set goes with this table? I see the 6mm and 8 mm set of the LMS website, but also see that 1/4" stuff would fit also,
Anyone have any idea? I may just make my own, but I thought I would ask first.
Jerry
dnsbss
12-15-2003, 10:03 AM
Harbor Freight sell a set of 6mm studs with stepped angle blocks and clamp for about $8.00, get 2 set, there are only 2 studsbblocks and clamps per set.
winchman
12-15-2003, 10:04 AM
I like the Sherline clamp set (part #3013, I believe) which came with my milling machine. The T-nuts are 3/8" square x 1/4" high, and the screws are 10-32.
Roger
billr
12-15-2003, 10:44 AM
good morning.
for what it's worth, i made some 1/4" t-nuts for my 6" r/t. ordered some 1/4" studs from somewhere. worked good. problem is that a 6" r/t is too small for most of what i do.
i think maybe it took an hour to make the t-nuts. you could also use some carriage bolts with the heads ground to fit t slots.
don't know if this helps, but it was a fast and cheap way to do it.
regards.
bill
jfsmith
12-15-2003, 07:12 PM
I checked with the LMS and this RT takes the 6mm set, which dnsbss was right get two sets. One set doesn't have enough to do many things. Right now I am using 6 mm allen head bolts to work as studs and milled some brass to be clamps.
thanks and Happy Holidays,
Jerry
