View Full Version : Emco Compact 5 lathe spindel
cole7015
11-28-2010, 04:02 AM
Looking for information Emco Copact 5 lathe. I need a drawing of the
headstock spindel bolt hole lay out. Anyone have the dimensions?
I need to make a new adaptor plate for a new 3 jaw chuck.
Any help would be greatly appreciated.
Thanks william
Circlip
11-28-2010, 04:07 AM
Tried the yahoo group??
Regards Ian.
Dennis WA
11-28-2010, 04:58 AM
William....Measuring my Compact 5, the spindle is 40mm diameter, bored 16mm. On the mounting face there are six 5mm tapped holes (0.8mm pitch) on a 29mm PCD - 4 holes are at 90 degree spacing for the 4-jaw chuck; the other 2 holes are spaced 120 degrees from one of the first-mentioned 4 holes, thus providing the holes for the 3-jaw and the collett adaptor.
As my machine is quite old, can I suggest you check the PCD by screwing in two M5 bolts or cap screws into 2 holes that are 180 degrees apart and measure the distance between them on the outside, subtracting the diameter of one bolt / screw to get the PCD.
Dennis
