View Full Version : OT - Lens polishing
SteveF
11-28-2010, 07:30 AM
I've got an older pair of glasses, standard plastic lenses, with a UV coating that is flaking off. These are the glasses I wear when things are flying and don't want to risk damage to my good glasses. Is there a fairly simple way to remove the entire coating?
Thanks.
Steve.
11-28-2010, 09:09 AM
No.
SteveF
11-28-2010, 10:07 AM
I was pretty sure that is what the answer was going to be but thought I'd check anyway.
Maybe I'll build a CNC lens grinder to skim off a thin layer!
Thanks.
Steve.
Astronowanabe
11-28-2010, 01:20 PM
straight (99%) isopropyl alcohol will take off (or at least loosen) some eyeglass coatings ... don't ask how I know ...
and yes I was able to remove the entire coating once it started
Paul Alciatore
11-28-2010, 02:27 PM
I am fairly sure that a belt sander will take it off without much effort. Or a disk sander. Or, well you get the idea.
A little extra pressure and it will remove both sides in the same operation.
beanbag
11-28-2010, 03:35 PM
http://arcoatings.com/
