View Full Version : Which drill bit for a 3/8"x16 tap?
Tony Ennis
12-31-2010, 05:12 PM
I'm drilling cast iron. This web page (http://www.stanford.edu/~jwodin/holes.html) says I need a .3320" (size Q) drill. However, my Machinerys Handbook says a 5/16" (.3125) hole is called for (assuming my threads are American Standard Form...) My tap is an H3 tap if it matters.
What's a newb to do?
(curiously, MH says a Q is appropriate for 3x8"x24 TPI threads.)
x39
12-31-2010, 05:16 PM
I'd use the 5/16" drill and not worry about it.
DougA
12-31-2010, 05:23 PM
akk the charts I have seen say 5/16 thats what I use.
bborr01
12-31-2010, 06:02 PM
Yup, 5/16
Paul Alciatore
12-31-2010, 06:05 PM
My tap drill calculator gives a value of 0.3141" diameter for a 3/8-16, 75% thread. This is close to the 5/16" (0.3125") drill size and 5/16" is probably as close as you are going to get.
The Q (0.332") drill would give you a thread that is only about 52% of the full thread form. This is a bit too small for my liking. For one thing, your actual hole would probably be several thousanths larger than the drill's size so the 52% would be reduced even further.
CI is relatively easy to tap. I would go with the 5/16" size.
beckley23
12-31-2010, 06:18 PM
Going from memory, I use a letter O, .316", for 3/8-16 threads.
Harry
DR
12-31-2010, 06:21 PM
My favorite tap drill chart lists drill sizes from .307" to .325" for a 3/8--16 thread. The length of thread engagement is the determining factor in drill size.
The longer the thread engagement the larger the drill.
oldtiffie
12-31-2010, 06:26 PM
Use 8mm x 1/25.4 = 0.315" ~ 0.3125" = 5/16"
I keep both inch drills in 1/64" (0.0156") increments and metric drills in 0.1mm (0.004") increments for just this reason.
http://i200.photobucket.com/albums/aa294/oldtiffie/Black_book/Black_book2_P32-33_1.jpg
Black_Moons
12-31-2010, 06:37 PM
I use an awsome thread chart that lists 50% and 75% drill size, in both fractional/number/letter/whatever is closest form, AND in decimal form, So I can actualy use my calipers to pick out a 'close enough' bit, And see just how close a perticular bit is.
Usally, In aluminum you want 75%, And steel/etc 50%, though I usally aim for somewhere around 60%~70% in steel.. because It makes me feel like im cheating and getting a better thread, but not stressing the tap too much with a 75% depth.
http://www.shender4.com/thread_chart.htm
motorworks
12-31-2010, 07:55 PM
Write This on the wall in ur shop for quick reference
TD = D - 1/N
and get a chart off the net...just a tip with stainless go 60 to as low as 50%
e
PS The book that Oldtriffie has a pic of is excellent for the price!!
hornluv
01-01-2011, 12:25 AM
Motorworks formula in easier to remember words:
Tap Drill Size = Major Diameter - Pitch
Pitch is the distance from a point on one thread to the corresponding point on an adjacent thread, so for inch threads:
Pitch = 1/Threads Per Inch
That formula will give you roughly 75% thread engagement when using a cutting tap (any tap with flutes). If you're using a forming tap you need to use a larger tap drill, otherwise the tap will bind because of the displaced metal.
The formula for forming taps is Tap Drill Size = Major Diameter - (Pitch/2)
Just in case you don't know how the thread designation breaks down, for 3/8-16, the 3/8 is the nominal major diameter and 16 is the TPI, so the pitch would be 1/16 or .0625". Using the cutting tap formula we get:
.375 - .0625 = .3125 for the tap drill
For metric threads, the designation is slightly different. In an M6 x 1.0 thread, 6mm is the major diameter and 1mm is the pitch. Both cutting and forming tap formulas are the same for inch and metric threads.
Tony Ennis
01-01-2011, 12:38 AM
Thanks all. The 5/16ths drill worked fine.
