View Full Version : Circular lights
Lew Hartswick
01-07-2011, 11:39 AM
Please a ref link to the thread on puting the circle of LEDs around the
quill of a mill. I cant come up with the right search terms. :-)
I think we will need 4 of them for the new shop. The IDIOTS that
did the lighting calculation for the new building ought to be strung up.
Will probably need something for the 8 lathes also. :-(
...lew...
sid pileski
01-07-2011, 11:49 AM
http://bbs.homeshopmachinist.net/showthread.php?t=34150&highlight=sid+pileski
If the link works- here's one I did.
Sid
deltaenterprizes
01-07-2011, 12:03 PM
I used a LED circular tent light to and a power supply from a ATT DSL computer modem. Works great.
kf2qd
01-07-2011, 04:43 PM
For those of you in North America (maybe only the US), Autozone sells a circular LED lamp that can be modified to work. I adapted mine to work on my Harbor Freight X2 Mini Mill by opening up the center hole and making a spring clip out of welding wire to keep the 2 halves together around the spindle.
Got it for $10.00.
Now I need to work on a 4.5Volt supply so I can do away with the batteries.
Will post pictures later -
biometrics
01-10-2011, 12:12 PM
Check Bob Warfield's website: http://www.cnccookbook.com/CCBlogMar2007.htm
...about half way down the page...
Lew Hartswick
01-10-2011, 07:08 PM
Boy that is some list of things. I found the light but am not sure I want
to build them (need 4) from scratch. Hoping to find something I can
just modify a bit and bolt to a bracket.
But thanks for the link. May have to build one of those "offset centers"
for the lathe tail stock.
...lew...
dockrat
01-10-2011, 07:21 PM
Lew, I don't know if this would work for you but this what I did on my mill:
http://bbs.homeshopmachinist.net/showthread.php?t=27846
