I have gotten by without a DTI somehow until recently.
the one I use most has the tip angled back from the body about 15 degrees, which makes it difficult to use for most applications.
I know that little tip should pivot to whatever angle is needed at the time, but I can't figure out how to adjust that.
The little slip of paper that came with it is no help, and none of my many machining textbooks on my shelves mention it.
So how do you adjust that without breaking it?
