jr45acp
12-29-2003, 02:10 PM
I've got a Jacobs Rubber Flex Collet chuck that came with the Clausing I picked up. I cleaned the cruD off of the chuck and discovered that there is still a Rubber flex chuck in it. I put the whole affair on the lathe, put it in back gear and tried (emphasis on tried) to loosen the hand wheel. That puppy must have been put on by someone that was really having a bad day. Bottom line, I can get it to loosen up. I am assuming that the hand wheel should turn counter clockwise (towards the operator). I've tried tightening, have soaked it down good with penetrating oil, but still can't get the blasted things to move. Any and all suggestions are appreciated. BTW, the lathe is not yet under power, so I'm stuck dealing with this based on brute strength.
I've dealt with 5C collet chucks and have never run into this. This is my first go around with a rubber flex type.
HELP!!!!!!!!!!!
John B
[This message has been edited by jr45acp (edited 12-29-2003).]
HELP!!!!!!!!!!!
John B
