What constitutes a type III Anodize?
Is it the thickness of the Anodize layer or the process used to achieve it or both?
I think I accidentally did one part this AM.The acid bath was around 28*f this morning and I had intended to run the part at 12vdc and 10 amps for 65minutes.Well I got busy and forgot it was running and the time function ended up being 1hr 10minutes-Ooops!
All went well anyway,but the part started out as measuring 3.001" OD and finished up at 3.010" or.0045" thickness in the Anodize layer.
So did I or didn't I?
