Bob Farr
02-23-2011, 03:05 PM
I recently acquired a nice ratcheting Diacro No.4 bender with a platform, quick clamp and a few limited pins and mandrels. I'm pretty excited about this find! I'm still checking around for a source of mandrels but I'll hazard to guess the factory made ones are NOT cheap.
http://i58.photobucket.com/albums/g272/frankenglide/Diacro41.jpg
I downloaded the manual from Diacro's site and it shows a couple styles of tube radius collars, forming rollers, and a long "following block" for forming a tighter radius in thin wall tube material. I highlighted them in these pictures:
http://i58.photobucket.com/albums/g272/frankenglide/Diacromandrel1.jpg
http://i58.photobucket.com/albums/g272/frankenglide/Diacromandrel2.jpg
I forsee using the bender for small diameter bar stock (1/4 - 1/2" OD) and 4130 tube (3/4 - 1-1/4" OD, 14-16ga max wall thickness). A concave forming roller for the bending nose doesn't look too complicated to make on the lathe, but the one-piece center mounted forming block (colored orange, teardrop shaped) and the long following block (colored yellow) seem a little more involved.
I have zero bending experience and not much more machine shop experience. I do, however, have at my disposal a Hendey universal 12-inch shaper, a Gorton O-16A universal vertical mill (2/3 scale Bridgeport), and a Sheldon 11x48 lathe. I'll also have a Van Norman No.6 horizontal/vertical mill ready for use soon.
How necessary is it for the inner forming block (orange) to have the teardrop shape? Could I make it in two parts: the round inner section turned on the lathe and the extended/clamping portion cut another way, then joined? What methods would be best for making the long groved following block? It the long forming block really necessary and an improvement over using a forming roller? Will shop made forming blocks need to be hardened?
Thanks in advance for any bending experience or advise you're willing to share.
Bob
Bob
