View Full Version : Old bearings to new,tricky
02-26-2011, 10:26 PM
Started working on my T&C grinder this week.First up was the motor,that checked,next were the spindle bearings.
They were rough as a cob so replacements were needed.Spent a couple hours disassembling the spindle and found two Fafnir MM9105 bearings inside.Angular contact ball,phenolic cage outer races marked "Thrust" 15* contact angle.
Popped out my Fafnir catalog,looked up MM9105,still make them,great I'll order a set-wait a minute.
Part number is now a MM9105K,look up what is K? K is Conrad type ball bearing,not my bearing:confused:
Looked a few pages over,it's now a 2MM9105WI:rolleyes: $189.00 ea.:eek:
So once again we have seen ,never,ever order a bearing by it's numbers only.
I did find a set of Nachi 7005CYDUP4 for $220.00 out the door,much better:)
Carld
02-26-2011, 11:42 PM
It's got so bad even though I look them up in a catalog I still call the bearing supply house to be sure of what I am ordering is right.
Can't they just leave things alone and not change the numbers every year or so.
philbur
02-27-2011, 04:55 AM
Is it possible that the manufacturer intends for them to serve the same function. Hence the same number, with a qualifier.
Quote from Wikipedia:
"Conrad bearings have the advantage that they take both radial and axial loads, but the disadvantage they cannot be filled to a full complement and thus have reduced load-carrying capacity compared to a full-complement bearing."
Seems to me that potentially the only effective difference is the actual load carrying capacity, which is not an issue with a T&CG.
Phil:)
macona
02-27-2011, 05:02 AM
As far as I know Konrad is a fancy name for angular contact.
lazlo
02-27-2011, 09:36 AM
Conrad means deep groove radial bearing. It can take axial and radial loads in either direct.
Darin's 9105/7005 is a thin section angular contact bearing. The 9105K is a Conrad == deep groove radial -- you don't want it :)
02-27-2011, 11:21 AM
Yup,not the same crossection at all.
CarlD,worst yet are oil seals,everytime one company buys another they feel the need to change the nomenclature,royal PITA.
