View Full Version : Cam Action Clamp?
gr8life
03-02-2011, 06:29 PM
I need to make a locking device to hold a block onto a shaft, much like the way a quick change tool post mounts. I need to have it lock without threads. The clamp, if i remember correctly, has a wavy base with a piece that will lock it w/ less than 180 deg. of turn, much the way a qctp feels when the wedges or piston locks.
Does anyone know how it is made or where I can find a drawing or other info.
thanks
ed
38_Cal
03-02-2011, 08:02 PM
Take a look at bicycle cam action seat post clamps. Some of the photos on EvilBay give enough detail that you should be able to work from them.
David
gr8life
03-03-2011, 12:18 AM
If this copies this is what I am looking for
http://www.techno-isel.com/LMC/Products/Ext_Accessories/Images/CAMLockClamp.jpg
Willy
03-03-2011, 08:22 AM
Not sure if this helps, but is it like a cam action edge clamp like in your link?
http://www.valtrainc.com/WHTools/cac.htm
Highpower
03-03-2011, 10:31 PM
Will a CAD file help any?
http://www.reidsupply.com/Detail.aspx?itm=CAC-10
gr8life
03-03-2011, 11:50 PM
Thanks for all the info. I actually made a test piece of alum. late this afternoon. Made it on the mill w/ rotary table and power down feed. I think I have the concept and will try to figure out the amount of slope/slant? tomorrow.
thanks
ed
