View Full Version : MiniMill head drop
Boot
03-04-2011, 09:47 AM
While using my HF Minimill the head dropped about 1/8 in causing a wreck. I smashed the small plastic gear under the motor . Leaving a gash in the new vise I was working on. Does anyone know how to adjust the play in the feed knob so this doesn't happen again when I get the new gear in? I think the gear was a scraficial type object because it is matched with a steel gear on the motor. Thank God for that. I patched the vise up with some JB weld and we're good to go again. Also even though it's HF I ordered the gear from Grizzly because of it being the same machine. Is that true of is it going to come back and bite me by being slightly different size? I figured I would get better service there.
Thanks Boot
WaveDude
03-04-2011, 11:34 AM
Join this group and search away--lots of good tips on minimizing this problem (you'll never solve it completely):
http://groups.yahoo.com/group/GrizHFMinimill/
The next best thing is to convert to a belt drive and air spring.
uncle pete
03-04-2011, 12:50 PM
Also upgrade the ratcheting head locks. Little Machine Shop sell better ones as an upgrade. Those are 10x better than the original factory supplied ones.
Pete
Boot
03-05-2011, 11:23 AM
I'm not going to invest in the belt drive right now, but I did just order the air spring kit from Little Machine Shop . That will most wholely solve my problem. Thanks for the advise. Boot
