View Full Version : Maple Syrup Electric Supply.
madman
03-13-2011, 12:09 PM
Received Electrical Info , I was advised to use (Buy) a C1F005XES TRANSFORMER, ENCAP, 5KVA, 515.00 1 515.00
220/120 Volt, 60 Hz
This would be hooked into a GS2-22P0 GS2 2.0 HP AC DRIVE 230V 1/3 244.00 1 244.00
PH IN 3 PH OUT
Total: $ 759.50 F.O. B Cumming, GA
This is to use the standard 120 volt line that can run a 2 horsepower electric motor to a Transformer ? that connects to the AC DRIVE which will connect to the vaccuum pump? Sheesh.. Where do you find used transformers klike this > ?
WOW those Hillbillys make the money. Was hoping a cheraper solutuin possible. That transformers expensive.. Mike
MaxHeadRoom
03-13-2011, 12:51 PM
You don't have 240v 1 phase available? Why is the transformers needed?
That VFD shows a price of $244.00 at Automation direct.
Max.
Black_Moons
03-13-2011, 05:01 PM
2hp at 120v needs a 20A circuit at least.
Your better off ignoring the transformer and wiring up a 240v circuit (Or rewiring a 120v circuit to 240v) and running a VFD off that.
