Looks like the start cap on my 30 year old Grizzly lathe has finally given up the ghost. The motor will start if there's no load on it, but as soon as I put the belt back on, it just buzzes. So here's where I need some help.
The motor is 1 1/2 hp, dual voltage and currently wired for 220 volts. The cap is 125 volt, 300 microfarad. I've never been able to run this thing at top speed, which leads me to believe the cap may have been breaking down for awhile. My question is, would there be any advantage to going with a higher rated cap? Or is that just asking for trouble? Some of the research I've done says start caps should be sized at 500 microfarad per HP, this one obviously doesn't come close. Something else leads me to believe that a higher voltage cap could also be a good idea. Don't know if it makes a difference, but I do tend to start and stop the lathe frequently.
One other question, are start caps temperature sensitive? As it's finally been warming up a little here, I've let my shop furnace go out, so the temp in there is probably in the 40's instead of the 60's I have when the furnace is going. I have an older Craftsman table saw that gets temperamental when it's cold, I need to give the blade a spin sometimes to get it going. Could the same thing be going on with my lathe? Thanks, gents.
