View Full Version : Looking for a special Knurl..need some help
Mike Hunter
03-27-2011, 09:46 AM
Looking for a special knurl, hopefully someone here can point me in the right direction. 56 LPI, with a SQUARE pattern not the normal diamond.
Any help will be greatly appreciated
Ken_Shea
03-27-2011, 08:36 PM
Mike,
Did not find any supplier for you but did find this, it may be of some help to you if your search comes up a blank.
" A good trick is to use a straight knurl and then use a sharp threading tool to cut grooves at regular intervals across the knurled surface, this gives an unusual and pleasing square pattern. don't do it the other way around because the knurling will squeeze metal into the machined grooves which doesn't look so good. "
RobbieKnobbie
03-27-2011, 10:42 PM
There was an outfit at this year's Cabin Fever that had litterally undreds of old knurls, from common diamond to nice rope, to some of the prettiest decorative patterns I've ever seen. Lace, paisleys, anything you could imagine repeated on a little metal ring.
I looked at them quite a bit, but their prices were steep and I couldn't narrow myself down to just one or two knurls so I wound up walking away empty handed.
Maybe someone else can remember their name or got a business card from them??? I certailnly wouldn't mind seeing if they have a web site!
gwilson
03-27-2011, 11:16 PM
I WISH I had seen them!!! I'm a total knurl pig!!!
ulav8r
03-28-2011, 12:03 AM
If you can pay the price, Accutrak can make most any knurl you would want.
Mike Hunter
03-28-2011, 09:52 AM
Thanks for all the feedback
I'll try Accutrak, it's a customer's project, it all depends on how bad he wants it.
Robbie... if you happen across the site or number I would be interested also,
V/R
DR
03-28-2011, 02:08 PM
They must be commonly available. I have several tools with knurled hand grips like that.
I'm assuming by "square" you mean circular grooves with longitudinal grooves.
RKW
03-28-2011, 02:33 PM
I think you are describing a knurl similar to what Gary Hart made on some small taps. Try this link to the homemade shop tools thread.
http://bbs.homeshopmachinist.net/showpost.php?p=513367&postcount=157
