A month or so ago, I gloated about my $150 Arboga gear-head drill press. Time, as always, has been against me, but I've managed to sneak in a few minutes here and there to fix of paint this or that part.
One of the worst issues with the drill was this section that got chipped out:
It's the boss where the clockspring went, which got broken out when the drill fell over. Fortunately, it fractured at a setscrew hole, which limited the damage. I could have left it alone and just redrilled a new setscrew hole to one side, but I decided I'd risk welding it up.
I picked up some more "Muggyweld" rod, which worked reasonably well on my old Rockford drill, and cut and ground a chunk of filler from one of the Arboga's switchbox fragments.
The welding was uneventful, as was the crack at the front of the casting (which I think predated the fallover) that you can see just to the extreme right edge of the photo.
After welding, which was kind of tricky due to the pressed-in-place motor windings (the motor housing is part and parcel of the head casting) I set it up on the mill and rebored the hole:
Not a huge project, but if nothing else, I'm glad to be finally making some progress on it.
Doc.
Doc.
