View Full Version : SX2 mini mill tach
Bmyers
03-30-2011, 08:09 PM
I have been tricking out my LMS mini mill. I knew the new servo drives had a port for a tachometer but the budget couldn't justify the cost. I did some research and found a guy at cnczone that had hacked the serial string and provided Ardiuno code to decode the string and drive an LCD.
I decided to copy his effort.
Prototype:
http://i485.photobucket.com/albums/rr219/j-bmyers/mini%20mill/ff3284d4.png
It works:
http://i485.photobucket.com/albums/rr219/j-bmyers/mini%20mill/7cc20860.png
Circuit board for micro controller and cable to display:
http://i485.photobucket.com/albums/rr219/j-bmyers/mini%20mill/b47c3090.png
Enclosure with display:
http://i485.photobucket.com/albums/rr219/j-bmyers/mini%20mill/be449d98.png
I tested with an auduino UNO but as soon as a nano arrives that will be controller that mounts on the pc board
Dan Dubeau
03-30-2011, 08:58 PM
Nice job. Are you going to machine an enclosure for it with the mill?
I envy you guys with the electrical and programming knowledge like this. I've just never been able to "get it". Wish I had a good and patient teacher, or even knew where to start to learn on my own.
