ibewgypsie
01-10-2004, 08:28 PM
Slo-Syn(r) Stepper tell a friend about this item so they can check it out
This clean 24 VDC takeout stepping motor from Superior Electric is 4-1/8" x 2" dia, with (24) 15-degree steps per revolution. It is (5) wire, draws just under 2 amps and has 65 oz/in torque. The bottom has a removable 2-1/4" square mounting plate and a 1" x 1/4" dia shaft ending in a 7/16" x 1" dia pulley. On the top is an identical shaft topped by a 1-7/8" encoder wheel, and a bracket that holds a 6-pin-edge zoom encoder. The motor's (5) leads terminate in a 6-pin molex-type connector.
34055 SYN STEP MOTOR $9.95 / EACH add to cart
SYN STEP MOTOR
http://www.sciplus.com/category.cfm?subsection=18&category=174
5 leads, usually you just use 4 for a gecko or a larken drive..
Hope this helps someone.
SYN STEP MOTOR
