"Operating temperature measures at about 165 F which is well below the rated temperature of the emitter. "
Evan, I have made a similar "bulb" from the same seller,( DealExtreme). I can't find any detailed info on the emitter, nor the driver. Where did you find you info? And, any idea what the operating temperature is at the junctions? I'm running about 175 F at the emitter.
