View Full Version : Rotating Mill head?
S&S_ShovelHead
05-15-2011, 03:57 PM
I bought a RF-45 copy mill/drill and am need to rotate the mill head 45 degrees. I loosened the two large nuts that hold the head from rotating and pushed on the top and pulled on the bottom hard trying to rotate it but it doesn't budge. Am I missing something?
Nosman
05-15-2011, 06:20 PM
One more nut up under the head, or at 6 o'clock if you like!
wawoodman
05-15-2011, 06:23 PM
I just glanced over this article, but maybe there is something there to help.
http://www.fignoggle.com/machines/rf45-dovetail-square-column-mill/index.htm
The parts may just be stuck together with whatever they coat it with to prevent rust. Maybe try dribbling some kerosene into the seam, and tapping into it with a putty knife.
S&S_ShovelHead
05-15-2011, 11:23 PM
That was it, thanks.
Nosman
05-16-2011, 09:27 AM
No problem, anytime.
