View Full Version : Reducing speed by 40:1 using VFD?
taydin
05-20-2011, 05:02 PM
My woodworking bandsaw has a 1400 rpm three phase motor. The blade speed is 1000m/min. In order to cut metal, the blade speed needs to go down to 25m/min, 50m/min and 100m/min. So at the extreme, I need a 40:1 reduction. Have seen threads where people did very nice pulley based conversions, but still wondering if a VFD can be used for this.
The frequency will have to go down to 1.25Hz, so the motor will be pulsing and vibrating a lot. Also, heat will be a big problem, especially since metal cutting can take a long time. Is there any way to make a VFD work for this application?
Forrest Addy
05-20-2011, 05:23 PM
Taydin, yes you can reduce a motor RPM over a 40 to 1 range by means of a VFD but there are a few big problems to consider. The first is stability. You will need a sensorless vector VFD one capable of compensating for the "slip" characteristic of every induction motor. The second is the mechancal power developed by an induction motor is proportional to its RPM. At 40 to 1 frequency reduction the motor will develop about 1/40 of its rated mechanical power.
An induction motor is a constant torque device. If the motor develops a Nm torque at 1440 RPM it can develop no more than 1 Nm at 1440/40 or 36 RPM. It takes more tractive force on the blade to drag it through metal. The 1 to 3 Kg needed for wood becomes 14 or so for steel. You need a mechanical reduction.
My suggestion is to set your saw up with two V-belt reductions. One for cutting wood and one for cutting metal. You change belts according to the material you wish to cut. Use the VFD to adjust the band speed to suit your work.
MaxHeadRoom
05-20-2011, 05:30 PM
Also one of the problems with sensorless vector is it start to lose its effectiveness a low rpm, the best way to get constant torque down to 0 rpm is with a pulse wheel or encoder option.
Max.
Arthur.Marks
05-20-2011, 07:00 PM
I've asked a few questions on VFD's over the last year. Usually I'm met with more confusion than answers by it all. Here's my take. I'm sure it'll get blasted down on a technical level, but it makes a good benchmark logic for the whole system in my head::p
A VFD system has three parts:
1) Horsepower (amount of power exerted)
2) Torque (amount of "mechanical" advantage available)
3) Speed (in this system, a function of Hertz)
If you change one, one of the other three will change in proportion. So, for example, if you halve the speed (i.e. Hertz setting on the drive from 60 to 30 in the USA) you will proportionally reduce the horsepower by half as well. In this example, the torque will then remain the same. That's the rule: two are affected in equal proportion for the third to stay constant. Generally speaking, the motors used on machine tools are of the constant torque type as explained by Forrest above. So it becomes a math problem of the following type:
*How much horsepower is necessary at 35rpm?
*Take that number and multiply by 40 for a 40:1 reduction in speed from the motor listing.
In conclusion, no. It won't work without using a pulley reduction or speed-reducing gearbox to bring the speed into a closer realm than 40:1. Both a pulley or gear reduction system are able to retain horsepower and torque while reducing speed.
MaxHeadRoom
05-20-2011, 07:15 PM
Not only retain torque, but torque increases by the ratio of the reduction.
Max.
lakeside53
05-20-2011, 08:20 PM
Heck yes. If you want 1hp for metal, just put a 40hp motor and vfd on your Bandsaw :D
I just traded "up" from my 14 inch Jet woodworking bandsaw to a Wilton (err... Jet) 8201. That has belts and a gearbox to cover 3300 to 39. But, that model is also 3 phase, so it's getting a $130 VFD anyhow.
PeteF
05-20-2011, 08:34 PM
As Forrest said, sorry but I'd suggest you need a mechanical reduction. While I have a VFD on my lathe and don't ever change speeds for normal operation, I still use the backgear when threading with dies at very slow speed, otherwise I can stall the lathe motor.
Pete
Langanobob
05-20-2011, 08:51 PM
Taydin,
I have an old woodworking bandsaw that has been converted to metal cutting with a very large pulley system It works very well, but it is now a metal cutting bandsaw and not used for wood anymore.
I had a thought, since it appears that a 40:1 VFD reduction isn't practical, what if you reduced the speed by a factor of 20:1 with a more reasonable sized pulley system and then went the next 20:1 with a VFD for a total 40:1 reduction? There would be some additional cost involved over a purely mechanical reduction, but it would not be as awkward in size.
Not sure if this might be the best of both worlds or the worst of both worlds but I thought I'd suggest it so that maybe someone more knowledgeable about VFD's could comment.
Reno, Nevada, USA is having a Turkish Cultural Festival on Sunday and I'm looking forward to going into town for a Turkish meal.
Bob
lazlo
05-20-2011, 09:10 PM
Putting what Forrest and Arthur said together:
Power = Torque X RPM
Induction motors are constant torque.
So if you halve the RPM with a VFD, you've halved the power:
what was a 1 HP motor at the rated nameplate RPM (1750 RPM), is 1/2 HP at 875 RPM, 1/4 HP at 437 RPM...
That's why electronic vari-speed conversions usually double the horsepower of the stock motor, which gives you a 4:1 RPM range with useful power.
Iraiam
05-20-2011, 09:15 PM
Hmmm, 1.25HZ on a 1400 rpm 60HZ motor is not going to net you much torque, not enough to cut metal is a safe bet.
Some VFD's have the ability to apply full voltage at a lower frequency setting for better lower speed torque, but I have not seen one personally that would do this at such a low frequency setting (1.25 HZ).
It sounds to me like a mechanical speed reduction may be a better option, or at least a more usable one.
taydin
05-20-2011, 09:39 PM
Thanks for all the responses guys. As I suspected, the VFD isn't the right solution.
As for using both a pulley and VFD, I think that would be overkill. Once I do the pulley system, I will already have all required speeds available, so a VFD isn't needed anymore...
lakeside53
05-20-2011, 09:44 PM
ah... but if you have a vdf you don't need to change belts often (choose one mid range, and vary 5:1 with ease), and there are many advantages to VFD's other then speed control.
05-20-2011, 11:56 PM
Closed loop control is the way to achieve very low rpms as MaxHeadRoom (my favorite TV series) wrote.
It works best using DC motors since a DC PM motor develops maximum torque at stall. Using PWM control and a DC motor with feedback you can dial in any speed you want down to zero.
Here is my mill operating with a closed loop Brushless DC motor with a 1/3 hp rating. It's geared down by about 2 to 1 which means the full speed rpm is reduce to 1500 instead of 3000. By using closed loop control it can be run at around 20 rpm if required. This was a temporary setup to test the concept.
http://www.youtube.com/v/lCIXC2aQy2Q?hl=en&fs=1
Forrest Addy
05-21-2011, 12:28 AM
Evan Yabbut maybe a little more than Taydin wants to hassle with for a bandsaw drive.
Don't get me wrong. I like DC motors and the ease with which the controls and quatrature feedback servos can be implemented via bone simple step motion technology
But even the fanciest 1 HP DC motor cannot offer a constant HP over a 40 to 1 range: 2500 RPM at ratings yields 2.1 lbft at ratigs. 2500/40 = 62.5 RPM - 84 lbft. Do the math to reproportion for your favorite motor.
05-21-2011, 02:57 AM
Horsepower is a function of rpm. It's a rate function, as in rate of material removal. That isn't what you need when you need low rpm cutting. What you need is constant torque over the entire rpm range rather than constant hp. Closed loop control of DC motors provides just that. It's torque that makes the cut regardless of the material removal rate. An induction motor can't provide high torque at very low rpm. It depends on rate of change of the stator field to induce high currents in the rotor. The slower it turns the lower the rate of change and the smaller the induced field.
A DC PM motor depends on the static current flowing in the windings to produce the magnetic field that interacts with the magnets. It produces maximum torque at zero rpm because there isn't any back EMF generated when the armature isn't moving. The armature in a brushless motor contains permanent magnets so the field is always present independent of the rate of change of the stator windings.
Low RPM torque is where permanent magnet motors shine. Pulse width modulation allows full voltage across the coils regardless of rpm. RPM sensing feedback provides accurate speed control even as the load varies.
The system on my mill is stupid simple. It uses a ring of permanent magnets on the motor pulley to generate an ac voltage by passing a coil as the pulley rotates. That is rectified and filtered to provide a DC level that is proportional to rpm. That DC level is mixed into the Potentiometer speed control voltage and regulates speed while still alowing for the pot to be able to control the desired rpm.
http://ixian.ca/pics7/closedloop2.jpg
Total electronics parts are one coil, a diode, a capacitor and a resistor.
http://ixian.ca/pics7/closedloop3.jpg
Forrest Addy
05-21-2011, 04:32 AM
Here we go again. Evan's loose. Where's the Bodger?
Evan, nice home brew solution to your singular, particular, isolated, specific problem. But will it answer Taydin's question? Will it simply solve his saw speed problem?
taydin
05-21-2011, 03:17 PM
The motor on the bandsaw is 2.2KW. The rating was no doubt chosen with wood cutting in mind. Everything else equal, I need a lot more power to cut metal. If I implement a pulley system, the major benefit is that the 40:1 reduction in speed will bring 1:40 increase in torque (the belt will probably slip way before this torque can be used, but in any case, there will be substantial increase in torque).
I can see the benefit of using a DC motor to achieve a wide range of speed control, but it seems I would need a DC motor that is rated quite higher than 2.2KW. After all, it must have enough power to cut metal and it doesn't have the advantage of torque increase through pulleys. Also, the driver circuit and the motor itself would be too expensive.
05-21-2011, 04:17 PM
You actually don't need a lot more power or torque to cut metal compared to wood. I cut both wood and aluminum om my small vertical wood bandsaw. It cuts both with ease. The main difference is cutting speed and depth of cut. Unless your primary concern is time it takes to cut then a 2 kilowatt motor is more than enough regardless of the type. That's three horsepower at full rpm. A two kilowatt DC motor will produce plenty of torque at low rpm. DC motors are far better at low rpm than AC motors.
However, in your case I would salvage some pulleys from a dryer and make a compound reduction. That is what I did for my shaper and it works fine. It has very similar requirements both for horsepower and rpm. I used a 3 hp single phase cap start/run 220 vac motor. It gives me 20, 40 and 60 strokes per minute.
http://ixian.ca/pics8/shaperdrive3.jpg
john11668
05-21-2011, 05:01 PM
10 Hz minimum in my book so some gearing down is essential
You could set the gearing for wood cutting speed at say 150 Hz if your bearings will take it.
taydin
05-21-2011, 05:31 PM
Here is what I think the belt system should be like:
Currently, the motor drives the bottom wheel with a belt/pulley and some reduction (maybe 2:1). I will remove the pulley that is attached to the motor shaft and replace it with a 2 stage pulley. One of these will drive the bottom wheel as usual and the other will drive the configurable, compound reduction (2:1 from the motor and 5:1, 10:1, 20:1 at another 3 stage pulley set). The compound reduction will always be driven by the motor, even when cutting wood. The bottom wheel belt will be switched between motor shaft pulley and compound reduction pulley. When not loaded with the belt, the compound reduction should not bother the motor significantly during wood cutting. Does this make sense?
05-21-2011, 07:31 PM
Sounds good to me. I should also point out that I only used bronze plain bearings on the jack shaft. As long as they are always lubricated they will last just fine and run with practically no friction. You need to provide oil grooves inside the bearings if you go that way and oil holes in the top.
Alistair Hosie
04-29-2013, 02:44 PM
Thanks so far guys I guess I will stick to my hacksaw and elbow grease it is not worth the hassle from your very educated responses I will leave alone many thanks and god bless. Alistair
metalmagpie
04-29-2013, 08:09 PM
Taydin, very few motors will run at all below 6Hz. And before you start thinking of just pulleys and belts, dig out "Machinery's Handbook" and look at the horsepower you can transmit before a belt slips. Most guys who do a wood bandsaw conversion wind up using a 10:1 gear reducer and then either belts or a VFD. Good luck, I enjoy your posts a lot.
metalmagpie
lakeside53
04-29-2013, 08:37 PM
As it was two years ago, I bet he figured it all out by now :)
