View Full Version : Keyway cutters for a shaper?
Bob Fisher
06-30-2011, 10:22 PM
What does a proper cutter look like? Especially for smaller bores (1/2in)? I bought the 7in Rhodes thinking that is one of the things it can do best. Anyone have a good site to show how to make keyway cutters? Thanks,Bob.
boslab
06-30-2011, 10:40 PM
i made one by bending a inserted tip [1/4"] boring bar on the anvil, the tip was ground like a parting tool to the key size plus a couple of tenths and the clapper was locked, i put a bolster plate behind the pulley [just a bit of old 1/2" plate with a hole burnt through it, short stroke plenty of soluble oil with a garden spray gun, worked a treat.
at home i have the luxury of a cinny toolmaster with a vertical slotting head on the back, just swing round and slot away, and to think they threw it out in work for lack of use, half the time i bring the work home as its less hassle, and they pay me+ give me TOIL so its a win win
http://www.google.co.uk/imgres?imgurl=http://www.micro-machine-shop.com/boring_bar_set_1.jpg&imgrefurl=http://www.micro-machine-shop.com/boring_bars.htm&usg=__YFm2e4qfhG5Yrwn9w9GbvWcP6XU=&h=407&w=640&sz=73&hl=en&start=0&sig2=bdwvSFd5AL_Iv0LA_DCAkw&zoom=1&tbnid=hB6JzSIexGPqrM:&tbnh=117&tbnw=175&ei=qzQNTta4CtCWhQfz9dXnDQ&prev=/search%3Fq%3Dboring%2Bbar%26um%3D1%26hl%3Den%26rlz %3D1R2SKPB_enGB370%26biw%3D1024%26bih%3D565%26tbm% 3Disch&um=1&itbs=1&iact=hc&vpx=695&vpy=124&dur=9703&hovh=179&hovw=282&tx=246&ty=80&page=1&ndsp=14&ved=1t:429,r:3,s:0&biw=1024&bih=565
the one at the bottom, you just make a square bar with a hole for the boring bar to sit in but i was too lazy and the gas axe and anvil were closer! remember to lock the clapper and run slow
mark
