View Full Version : Quick project for sine bar
mototed
07-10-2011, 04:05 PM
At last had a little time in the shop. Way too hot outside. I copied this off of some other picture I saw on the web. But it's quick and dirty. I think it could be useful for setting the compound angle. All I had was structural steel for the plate, so I went ahead and painted it to cover up some deep rust pits, but it still works as far as function. The pictures explain it all.
http://i217.photobucket.com/albums/cc28/mototed/IMG_0034.jpg
http://i217.photobucket.com/albums/cc28/mototed/IMG_0035.jpg
bob ward
07-10-2011, 07:06 PM
I too was very impressed with the angle plate device you refer too, and have placed it at the top of my round tuit list.
http://www.practicalmachinist.com/vb/general/angle-cuts-manual-lathe-228282/
mototed
07-10-2011, 08:49 PM
Yes, thats the one I saw. It's a quick project out of what ever is laying around and easy to build.
More weird tools that the grandkids will never figure out:)
Ted
Steve Seebold
07-10-2011, 11:03 PM
That will work great if you plan on running the spindle backwards.
winchman
07-11-2011, 01:21 AM
Please explain why.
MichaelP
07-11-2011, 10:16 AM
I guess Steve never needed to turn a taper which had the larger diameter toward the tailstock. Or (if the sine bar is flipped over) didn't need to turn long enough pieces with a "regular" taper at the end, so that the compound wouldn't hit the chuck. :)
loose nut
07-11-2011, 07:11 PM
It's only a ledge to rest the bar on, just reverse it end to end.
