View Full Version : Spindle oil loss rate - SB9 (cast iron bearing)
martik
07-11-2011, 09:03 AM
How much oil loss is normal for these? I was getting 2-3 drops down BOTH sides of the headstock per hour of run time. Now, only the small end leaks any oil and the resevoir on the large end stays full. Wicks are in ok shape and fully soaked with oil. I have removed the spindle several times and both ends of the spindle have a good oil film on them, no heat buildup or noise, bearing play is within spec.
DonT
07-11-2011, 09:12 AM
I have the same lathe in the cabinet model and get very little running out. I aways check the cups each time I use it and give it a squirt to keep it topped off but no noticeable leaking...
DonT
flathead4
07-11-2011, 11:08 AM
Martik,
My SB 9A is like yours, i.e. the small end leaks a bit. I just wipe it up and keep it full.
My complacency might come from those years of riding a '71 Triumph. At least the SB doesn't spray oil my pants leg. :D
Tom
Black_Moons
07-11-2011, 02:19 PM
I call oil leaks 'Chassis lubrication systems'. It sounds so much better then 'oil leak'
07-11-2011, 03:05 PM
A few drops per hour is perfectly normal. The lubrication schedule for the spindle reservoirs is "daily".
aboard_epsilon
07-11-2011, 04:25 PM
Think the back bearing has a smaller lip on it , where as the front one has a larger deeper lip ...so the front oil gets recycled and drains back ..whilst the rear..the lip is barely large enough to contain the overspill.
may even be designed like that so overspill gets into rear ball bearing and fiber washer
all the best.markj
martik
07-12-2011, 01:11 AM
Thanks all.
Well I guess it is nothing to worry about. I still don't understand why the leakage suddenly stopped on the large end. Maybe the bench level changed?
