View Full Version : push button switch
jaybird
01-22-2004, 09:43 PM
I am looking for a motor control switch, a two button, start/stop 220acv 20-30amp. I am coming up empty searching the net. Will someone give me a couple of manufactures or links?
ibewgypsie
01-22-2004, 09:49 PM
Usually, two button switches are One stop button wired hot one side, other side to start and hold contacts on a electric starter or relay (to maintain the contactor closed untill the stop is pressed) . Other side start button directly to coil of magnetic starter or relay to pull it in.
it takes 3 wires. A starter or motor relay takes more.
What are you wanting to turn on and off? a motor? you need a manual starter for that, it has the buttons made into the contactor. Push the start and the contacts close via a rod or mechanical connection, stop and they open.
Ebay is the most cost easiest to get. I use them all the time. Sorry I don't have any manual starters laying around here.
I'll help if I can, tell us a little more about what you want to do, and we'll help you get there.
David
Paul Alciatore
01-23-2004, 12:49 AM
I would try Grainger for motor start/stop switches.
www.grainger.com (http://www.grainger.com)
You might also try McMaster-Carr
www.mcmaster.com (http://www.mcmaster.com)
or Graybar - sorry I don't know the URL.
[This message has been edited by Paul Alciatore (edited 01-23-2004).]
Ian B
01-23-2004, 01:04 AM
Burden Surplus Center might have something - look under the "electrical" tab:
http://www.surpluscenter.com/
hth,
Ian
Thrud
01-23-2004, 01:12 AM
Any company that sells industrial controls such as Westburne or Westco/Westinghouse sells the industrial 1-1/4" Oiltight panel switches and indicators.
jaybird
01-23-2004, 01:49 PM
thanks guys
J
