View Full Version : ZAY 7032G Mill help?
Woreout Nut
08-01-2011, 01:19 PM
I recently purchased a ZAY 7032G Mill at a Going out of business auction.
It's brand new but did not have the "Accessories pack". I need a spindle draw-bar for it and collets.
Any help?
RobbieKnobbie
08-01-2011, 01:34 PM
A two second google search yielded this...
Giant Tools Zay Mill Page (http://www.gianttools.ca/productdetail.htm?ProductList=14&ProductDetail=92)
and that links you directly to the manual...
Zay manual pdf (http://www.gianttools.ca/ProductManuals/ZAY7032FGBENCHMILLING&DRILLINGMACHINEOPERATINGMANUAL.pdf)
If you can't get parts from there, try cross referencing your mill to similar Grizzly model. They are good with parts orders.
Woreout Nut
08-01-2011, 02:00 PM
Found the Gaint site and PDF manual but no parts.
Any help on cross referencing to a Grizzly Mod.?
Toolguy
08-01-2011, 02:30 PM
First you need to determine if it has a #3 Morse taper or R8 taper. If you look up in the spindle, a Morse taper is a long straight taper. An R8 is a short taper, then a straight hole.
loose nut
08-01-2011, 02:41 PM
A draw bar can be made simple enough, Most of the cheaper mills are just a piece of round bar threaded on one end for the collet and have a nut pinned onto the other. easy peasy.
Tinkerer
08-01-2011, 03:36 PM
I have the same mill... it's R8 for the collet. Can give the dimension for the draw bar if you like. You can make one up way cheaper then buying one.
Black_Moons
08-01-2011, 03:48 PM
Threaded rod, Nut, washer, Loktite (or weld or mangle some threads, or whatever way you perfer to attach nuts onto threaded rod to make a bolt head), Drawbar done.
Collets? Just buy a new set of whatever fits into your spindle type.
Toolguy
08-01-2011, 04:31 PM
That mill comes with either a MT3 or a R8 spindle. A MT3 collet can have either a M12 x 1.75 or 3/8 - 16 thread. An R8 collet has a 7/16 - 20 thread. It might be good to figure out which thread to use before making a drawbar.
Woreout Nut
08-01-2011, 04:44 PM
I have no collets yet. R8 collets are available locally. As is 7/16x20 all thread.
Is that all I need to get started? + tooling of course.
Woreout Nut
08-01-2011, 04:48 PM
Thanks. I have 3ft of 7/16x20 all thread on the way. Also found R8 collets locally.
How do you like your mill? Any problems I should watch for?
Tinkerer
08-01-2011, 09:03 PM
Like mine just fine... only a few issue. Lost a Start Cap (no biggy) and had a leaky seal on the range selector. Called about part they wanted 30 bucks. Bought a set of seals on ebay from a seller in Israel for a few bucks shipped. And a bad screw in a gear cluster... easy fixes all of them. Had fun snugging cutter in collect but worked up a wrench to hold the spline shaft while snugging up draw bar. It's a good machine and have seen some outstanding work on these type mills. Look at gbritnell work.
http://bbs.homeshopmachinist.net/search.php?searchid=722018
It will inspire you ;)
.RC.
08-01-2011, 09:21 PM
So long as you know you have an R8 spindle... My ZAY 7032G has a 3 morse taper spindle..
Black_Moons
08-01-2011, 09:26 PM
Really hope you have an R8 taper. Heres how to tell them apart:
R8 steep taper is about 1" long, then a longgg straight section thats about 1 1/4" (iirc. Might be a little off). Im not sure what the nose is of an R8 tool (tip of spindle) but I would suspect at least 1 1/2"
R8 -> http://www.thesurfacegrinder.com/wp-content/uploads/2011/02/R8-end-mill-holders.jpg
MT3 taper is a shallow taper thats about 4" long. The nose end of MT3 (Tip of spindle) is only about 20mm (0.8") in size.
MT3 collet: http://www.eyespygifts.com/product_images/sealey-power-tools/sea/sealey-collet-mt3a9bm12-o-14mm-s.png
Woreout Nut
08-02-2011, 05:33 PM
Definitely R8 taper.
Made Draw-bar from 7/16x20 B7 all thread with tallnut tig welded to the top.
I haven't milled anything yet (waiting on end mills and other tooling) but used collets to hold drill bits and drilled a bunch of holes, works great!
Thanks everyone for all your help.
