View Full Version : Hexagonal Boring video
RussZHC
08-16-2011, 02:14 AM
Heard of and have seen video for square hole drilling, this is hexagonal boring
http://www.youtube.com/watch?v=T4q8gCpeY1A
macona
08-16-2011, 03:56 AM
Looks like a horrible finish.
Wont be replacing rotary broaching or regular for that matter. The acceleration rates needed to do it at a useful speed would be very high.
skunkworks
08-16-2011, 02:24 PM
He used the same concept within EMC2 in this video also
(Eccentric / Non-circular turning using CNC)
http://www.youtube.com/watch?v=FpP7iTKuWpw
Andy did a cool hobbing video also
http://www.youtube.com/watch?v=ZhICrb0Tbn4
(emc2 is awesome :) )
Toolguy
08-16-2011, 05:48 PM
It looks like the wrench is pretty wobbly in that hole. Definitely not precision. I would say a crude way to use technology. As an experiment to see what can be done, it has some value in that we know more now than before.
skunkworks
08-16-2011, 05:51 PM
This was just to see if it could be done...
quoting andy
It's a singing pig, it isn't that it sings well, but that is sings at all.
Black_Moons
08-16-2011, 05:58 PM
Hmmm, I kinda like the idea. Consider that 'form relief' gear cutter from another thread, What if you did it by cam on a manual mill insted of by CNC?
That'd screw with those CNC people allright. "Yea my manual mill bores hex holes, at a few 100rpm, How about your CNC? Awww only 10rpm? And you have to hand crank the spindle? Sucks to be you"
Of course what you don't tell em is your using a grade 8 bolt of the right size for a cam, and that it likey wears out after a few operations at that speed :)
im thinking you'd want something compound sized or maybe a little smaller for a low mass dovetail... if spring returned, you could rough it out at higher speed and let the cam float a little, then slow it down to make the detailed corners.
And as far as wrench wobble, He likey just set the diamiter wrong, Id think accuracy would be how well formed it is when set correctly, and if it quickly wears to a slightly larger size due to high spots that wear off quickly.
skunkworks
08-16-2011, 06:03 PM
yes - another qoute from andy
And the wrench is indeed wobbly, I got the tool offsets wrong and made a Torx by accident, truth be told.
MaxxLagg
08-16-2011, 06:32 PM
http://www.youtube.com/watch?v=Tk-r1MNHYX4
Pretty impressive.
RussZHC
08-16-2011, 07:25 PM
Agreed, Maxx.
One almost begins to wonder it the "oddness" that is mathematically possible has a use/value or if some things will be done "just because they can", along the lines of proprietary and then cause grief later...
