I have an issue with an alternator on my Jeep. When I got it the alt would discharge the battery because it would bleed off over a few days. I put a diode in the wiring per the drawing and that cured the problem for a long time. Lately I started noticing the battery was not up to snuff if I didn't drive it everyday.
I checked the diodes and they were ok so just for kicks I replaced them. There is still a voltage drain through the alternator. I checked the output post on the alt for a defective internal diode and they appear to test good.
I don't really want to replace the alt unless I have to because I can disconnect the battery real easy each night.
What puzzles me is since I have diodes to eliminate feedback how in the hell is it discharging the battery?
I can unplug the two wire plug on the side of the alt and it won't discharge or I can disconnect the battery and it don't discharge. All this is in the alt. and I would like to know why and how. I don't have the 10 ga wire from the neg post to the alt ground but it is grounded from the engine to the frame to the battery.
