View Full Version : 1/2" bronze plate got sawed up today.
gwilson
09-22-2011, 10:19 PM
Using the Milwaukee metal cutting saw I bought used from Ebay,and a new blade,we got the 4' x 8' x 1/2" bronze plate cut into 6 pieces that are 1' x 4'. I left 1 piece 2' x 4' in case a larger piece is needed.
Chris Vesper,the toolmaker from Australia,has been staying here all week,and was a very big help,as my knee has gone bad this last month.
The smaller pieces weigh about 100#,and are manageable to get them up onto the Roll In bandsaw.
This is something I have wanted to get done for a long time.
boslab
09-23-2011, 12:53 AM
Well done! sorry bout the knee, hope the swarf didnt sting too much!
mark
Black_Moons
09-23-2011, 01:19 AM
What, no pictures of the awsome cut it left? or all the swaff? :(
flylo
09-23-2011, 01:38 AM
What are you making with it?
EddyCurr
09-23-2011, 01:58 AM
This is a Milwaukee 6370, correct?
How did it perform relative to the directions in the manual regarding cycle
times for material thicknesses beyond 1/4" ?
From pg.10 of the Owner's Manual (http://www.milwaukeetool.com/CatalogItem/Attachments/13268_58-14-6370d7.pdf)
The following are duty cycles to be followed by subsequent
cool down intervals of 60 minutes switched off (or 6 minutes
of no-load operation).
Cap ..... Max Dur ... Max Leng ... Feed Rate (Sec / Inch)
3/8" ... 30 - 40 sec ... 15" ...... 2 - 3
1/2" ... 18 - 36 sec .... 9" ....... 2 - 4
5/8" ... 18 - 30 sec .... 6" ....... 3 - 5
3/4" ... 20 - 25 sec .... 5" ....... 4 - 5
Earlier discussions: Metal Cutting Circular Saws (http://bbs.homeshopmachinist.net/showthread.php?t=49390) & How to cut 1/2" thick Naval brass (http://bbs.homeshopmachinist.net/showthread.php?t=49290)
gwilson
09-23-2011, 09:22 PM
It took about 5 minutes of total actual cutting time to make each 4' cut. We let the saw cool down and made knurls while waiting for the saw to cool.
I am not doing anything with the bronze yet,as I am pretty out of it with my knee. Just wanted to get it into manageable size pieces so it COULD be used later on.
The saw performed fine. I had bought a new 42 tooth blade for it. The blade still seems fine after the cutting.
EddyCurr
09-24-2011, 03:17 PM
The saw performed fine.That is a bit more aggressive than the rate suggested in the manual for 1/2".
Sounds like the saw performed well and withstood the heat buildup, nonetheless.
Thanks for the follow-up. Here is hoping that you enjoy better mobility and
comfort soon.
Peter.
09-24-2011, 03:36 PM
Those saws are surprisingly good. Our firm has two guys use two of them to dismantle a large steel chimnea recently. Our fellow went to make a demonstration and when he got this small hand-held circular saw out of the boot of his car he got a lot of mocking and derisory remarks from the assembly - until he ran it along a 15mm thick plate with little effort.
