View Full Version : Oldham shaft coupling repair
John Stevenson
09-24-2011, 12:11 PM
Many DC motors in fork trucks drive a hydraulic pump thru an Oldham coupling.
These are neat devices that allow a shaft to be out in two planes yet still connect them without ripping a coupling to pieces.
More info here:- http://en.wikipedia.org/wiki/Oldham_coupling#Oldham.
In many cases the end of the shaft has the tongue directly machined into it. When they wear they wear the ears off the ends on opposite sides to correspond with the loading. These can easily be repaiered with welding and regrinding back to standard.
Occasionally they can twist the tongue off all together and you can often get away by cutting a mating slot across the end and letting a flat piece in and welding.
Couple of weeks ago I got one of the new series of fork truck motors in for this type of repair. Instead of using DC motors that run off the vehicles own batteries and can work out very expensive, some cost 6K each they are now using off the shelf three phase 440v AC motors, read cheap and an inverter that takes the 36v / 48v of the vehicles batteries and inverts it to 440 volt 3 phase, which works out about the same cost but far more reliable [ usually ]
This motor had screwed the drive dog off the end. forgot to get a picture nut in this close up of the repair you can see the broken part on top of the bearing diameter.
http://www.stevenson-engineers.co.uk/files/oldhamshaft1.jpg
Can't weld this back on as it just wouldn't last, can't mill a straigh slot as the bearing fits right up to the end.
So decided to make a blind pocket and sink a hardened key into the pocket.
http://www.stevenson-engineers.co.uk/files/oldhamshaft2.jpg
Overall view of the setup, armature on vee blocks and clamped firmly to the bed. Horizontal attachment fitted to [a] turn the drive thru 90 degrees and [b] try to stiffen the POS Bridgy up.
Using the Z DRO to find centre and the Y DRO for width a slot was put in 30mm deep.
http://www.stevenson-engineers.co.uk/files/oldhamshaft3.jpg
Piece of gauge plate was ground and milled to fit, then loctited into position.
http://www.stevenson-engineers.co.uk/files/oldhamshaft4.jpg
End result after coming back from hardening and cleaning up, pressed in with a dollop of Loctite and the job is probably stronger now than when it was new. The bearing will prevent it from trying to splay the shaft.
lakeside53
09-24-2011, 12:17 PM
Nice! Must be great to have a place across the street to get hardening done quickly.
Is that key symmetrical with the shaft - maybe an optical delusion, but it looks off the the lower right.
Hey, you sure are using that using your pos BP a lot lately ;)
Robin R
09-24-2011, 03:41 PM
I think he's just getting some use out of it, before the TOS leaves and there is a better path to get rid of the Bridgeport.
Iraiam
09-24-2011, 04:00 PM
I have seen that type of drive on various pump drives also, mainly oil circulation pumps.
Now I know what to call them, Thanks.
Bill McLeod
09-24-2011, 04:12 PM
I run into various types all along the same line on marine propeller shafts they work good and also insulate for electrolysis. Seem Ok to about 100hp. Thanks as now I know the history.
boslab
09-24-2011, 10:53 PM
As ever a nice job. nice to see some proper engineering instead of tywraps and weld like i get in work, if it cant be fixed with a stilson, hammer and some black tape reinforced with a tywrap it cant be fixed, so throw it in the skip
regards
mark
09-24-2011, 11:26 PM
Nice save,see,you can do anything on a Bridgeport:D
914Wilhelm
09-25-2011, 01:00 AM
On the original setup was the drive dog machined with a radius to the shaft or was there an acute angle? Just wondering if the original manufacturer created a stress riser.
davidwdyer
09-25-2011, 04:58 AM
Thank God for that Bridgeport eh.
A.K. Boomer
09-25-2011, 06:21 AM
Where there's a mill there's a way;)
It is true SJ - for all the bad mouthing you give that mill it sure provides you with allot of face feedings and ale drinkings... whut up wit dat bro?
Anyhoo --- I too am very fond of the oldham coupling --- I think their pretty neat and so damn simple to make and they can be used in so many applications.
for those who still don't understand the concept I dug up my old bike trainer pic where I had to link two gens together and I built an oldham to do it - the fact that the transmission disc is black and the drive and driven couplings are white makes it an ideal self explanatory picture...
http://i146.photobucket.com/albums/r249/AK_Boomer/DSC00032.jpg
