View Full Version : Kant Twist Clamp Knurler
Joel R
09-30-2011, 09:44 PM
Has anyone on here built a scissor type knurler out of a Kant Twist clamp? It appeared to be a quick, cheap, and easy way to build one of these.
My quick google search turned up one example on this page:
http://hobby-machinist.com/index.php?topic=2175.10
Anyone build something like this? Any hiccups or suggestions?
-Joel
MichaelP
10-01-2011, 01:25 AM
Interesting idea, but the clamp is not sturdy enough laterally. It will work for sure, but I'm afraid it'll be another "chinese verson" of the tool. :)
camdigger
10-01-2011, 02:15 AM
Personally, I'd be a bit skeptical of the strength of the Kant twist from axial forces. They look strong enough to handle the radial forces, but axial???
For a real radical knurler check out post 47 or so of the shop made tools sticky. I use it to knurl in the drill press:eek: :D
If history repeats, this should lead to a multipage debate.......
strokersix
10-01-2011, 07:34 AM
I've done it. Agree with the limited lateral stability comments above. I needed to knurl a 3" diameter aluminum sheave. Got the job done but wasn't pretty.
