I made a slight error on my 1st hole in trying to bolt my lathe down. Re drilling not an issue, but it got me thinking.
In its current position, from the edge of the bench to the center of the chuck is just a hair over 15". To get close, I would lean over. I 1st thought it would make my back tired, but then I realized that I dont lean over very much. Plus it gives me more real estate on the front of the bench to put things on.
So what is normal/standard or even what do you guys have for a set up? I am almost 5'11 and the height from center of chuck to floor is 47" and the height of my bench is 33" which puts it across my hips and leaning into the bench to lean over is a nice support.
Leave it or bring it in closer the 4" I am off?
