View Full Version : Warner magnetic brake
Davidhcnc
10-18-2011, 02:25 PM
Warner magnetic brake.TB 1000...has anyone got experience of these things and could tell me how they work? How to set up and how to maintain?
http://www.warnernet.com/PDF/P-771-WE_pg072-077.pdf
and some good pics of the magnet on this ebay link
http://www.ebay.co.uk (http://www.ebay.co.uk/itm/5302-631-005-Warner-PC-100-Motor-Magnetic-Cluch-Brake-/250853801854?pt=LH_DefaultDomain_0&hash=item3a680d3f7e)
So I am having a bit of trouble with this one...there are things that defy logic.
Maybe PM me for a talk so as not to bore everyone
MaxHeadRoom
10-18-2011, 03:19 PM
If you are looking for the brake device, they are fairly simple, one side is connected to the machine frame and the other a rotating disc that attaches to the rotary shaft, a DC voltage is usually used to energize the brake, this clamps the rotating disc to the stationary one for braking, you can get alternative types, one that brakes with power on, the other requires power to remove the brake action.
The clutches are a very similar principle.
In many applications you do not need a fancy controller, a simple DC bridge will work.
The 90vdc shown can be run directly off 120vac with a bridge, although being in the UK your AC off the mains would be 240vac.
Max.
Davidhcnc
10-18-2011, 03:47 PM
Yes, Max, I thought they were fairly simple.
The bit that I don't get is the rotor and stator run steel to steel, the steel referred to is the ring inside and outside the friction lining.
So my problem boils down to two questions.
How to stop this thing squealing?
How do you know when it needs replaced?
....and thank you.
MaxHeadRoom
10-18-2011, 04:07 PM
I have personally never come across one that runs steel to steel, as the ebay link shows, it is usually a composite material similar to that used in auto brake pads or manual transmission clutches, either asbestos or now more likely some other composite material.
Max.
duckman
10-18-2011, 04:33 PM
When they squeal its time to change the magnet, there is a composite material with the coil embedded along with a plate to make the magnetic attraction that makes it work. By varying the DC voltage is how much braking you get.
Davidhcnc
10-18-2011, 05:30 PM
This one is not long new and has most of the lining thickness intact (has a wear indicator hole). Out of the box the magnet was skimmed flat, the steel body being the same level as the friction material.
Its mating cast iron rotor is also flat.
I understand the voltage and magnetic and braking power thing. My trouble is the steel rings on the magnet( as seen in the ebay pics) rub in the rotor and wear themselves into the rotor as wear progresses....and want to sqeal as they go.
Something in me says the friction material should be higher than the steel but that is not the way it is made....
maybe this is an uncommon version.
but keep talking, i am out of ideas to make it run quiet.
MaxHeadRoom
10-18-2011, 05:47 PM
A couple of Warner engineering articles.
http://www.warnernet.com/PDF/AutoGapFeatures.pdf
http://www.warner-china.com/DAINCI1.pdf
Not sure if it will help?
Max.
Davidhcnc
10-18-2011, 06:02 PM
.....reading. Thanks for taking the time.
jugs
10-19-2011, 03:33 AM
Oil/grease or Ear-muffs http://www.smiley-faces.org/smiley-faces/smiley-face-whistle-2.gif (http://www.smiley-faces.org)
