View Full Version : LIQUID GUN BLUE - CHEMISTRY
INTERPOLATE
02-05-2004, 05:18 PM
Greetings group.
Does anyone know anything about the chemical make-up of gun blue?
I have used it for years to identify stainless steel(a little bit on the end of a needle). Finally someone asked me questions about it and I had no idea.
Is there another way to quickly identify whether something is stainless steel or not?
Thanks!
DJ
Cass
02-05-2004, 05:35 PM
Get the MSDS sheet on the gun blue. Use a magnet for stainless steel. At least the austenitic alloys are not magnetic. A grinding wheel will tell you something also.
tonydacrow
02-05-2004, 05:56 PM
Interpolate,
If you're talking about "cold" gun blue, (as I assume from your use to quickly ID steel) they are usually solutions of selenium oxide. Hot blue uses lye and sodium nitrate in a super saturated hot water bath to create a hematite (Fe203 I believe)coating over the steel in a controlled rusting process.
