tcalef
11-27-2011, 08:59 AM
I've been reading as much as possible, and have some questions before I start this process. First off, I have a Boss IV cnc, where all the steppers and controls work, the machine is in really good condition. My aim is to get this machine running with Mach3 for hobby milling (no plans on servos)
1) I've ordered a 5hp rotary phase converter, but it looks like VFD may be the way to go. On eBay, the VFD's look like $200, so I think I could get one of those and 3 drives for the same cost of the RPC.
2) It looks like most people build their own power supply to give the steppers the right DC voltage. What voltage are the stock steppers supposed to run at? I am assuming that the power supply needs to convert 220 VAC to that voltage, but at what current?
In the end it looks like new drives are more recommended, but from a system approach, is it better off with a RPC or should I switch the incoming power to 220 and run the spindle off of the VFD?
Thanks,
Tom
Thanks,
Tom
