View Full Version : Drilling A Square Hole, MUST SEE
JoeLee
12-10-2011, 04:26 PM
I have to say that this is a first for me other than using a mortising chisel.
However ............ not going to work with a hand drill or light duty drill press.
JL................
http://mail.verizon.com/webmail/driver?nimlet=download&fid=INBOX&mid=9578&disp=attachment&partIndex=1
tmc_31
12-10-2011, 04:31 PM
Dang JL, I would like to see a square hole being drilled but nothing comes up on the link.:(
Tim
Willy
12-10-2011, 04:33 PM
Joe your link isn't working for me.
Is this perhaps what you are linking to?
http://www.youtube.com/watch?v=ALiqAXiTQBg
http://www.youtube.com/watch?v=Iz3pDMP7IsE
Arcane
12-10-2011, 04:36 PM
It`s a Watts drill. The original patent was applied for back in November 1916 and the patent, #1241176, was granted September 25, 1917 to Harry J. Watts of Turtle Creek, Pennsylvania.
JoeLee
Willy,,,,, yes that is the link. The link I posted worked when I checked it!!
JL.....................
JoeLee
12-10-2011, 04:37 PM
I'll be........... I guess they never gained popularity, I've never seen them in any tool catalogs.
JL................
aboard_epsilon
12-10-2011, 04:46 PM
well hes turning in his grave now that the chinese are selling them.
all the best.markj
JoeLee
12-10-2011, 04:49 PM
It figures that it was invented here and reinvented years later across the pond.
JL.................
Lew Hartswick
12-10-2011, 05:59 PM
Has anyone here used one? I have a question. How do you "index"
the square?
...lew...
aboard_epsilon
12-10-2011, 06:02 PM
its probably good for 4-5 holes ..then its worn out
all the best.markj
JoeLee
12-10-2011, 06:04 PM
the square?
...lew...
Thats a good point. You would have to locate an edge of the cutter in relation to where you want your corners to be or no telling where your corners will end up.
JL................
lakeside53
12-10-2011, 06:51 PM
Was everyone asleep? :D
There was a thread on this a month or so back!
lazlo
12-10-2011, 07:13 PM
That's Dijet -- a Japanese company. Their headquarters is in Osaka.
Toolguy
12-10-2011, 07:30 PM
I called them and tried to buy one. The person at Dijet told me they are only sold in Japan, not available here.
danlb
12-10-2011, 07:40 PM
Look at this video to see how it is done. The cam rides in a form that establishes the path of the cutting edges.
http://www.youtube.com/watch?v=L5AzbDJ7KYI
Dan
12-10-2011, 09:45 PM
Not the Watts method, but a method that is "inside out" from the Watts method. May be better, actually, since no guide is needed at the work.
The Watts has the shape of drill, but with a rounded corner. No cam, the cam IS the drill, turning in the guide which is the round piece inside the holder in the picture. Guide is harder than the hobs of H###
Drills a good enough hole for many things, including socket wrench square drives.
http://img.photobucket.com/albums/0803/jstanley/watts1s.jpg
Using it in the lathe
http://img.photobucket.com/albums/0803/jstanley/watts1a.jpg
to make a specialty socket wrench end
http://img.photobucket.com/albums/0803/jstanley/draintool2.jpg
http://img.photobucket.com/albums/0803/jstanley/drain_tool1.jpg
383 240z
12-14-2011, 05:42 AM
Turtle Creek was the home of George Westinghouse, at that time. Yeah, that Westinghouse. WABCO, or Westinghouse Air Brake Company. Back when great things were being built in the Steel City of Pittsburgh. I wonder if Mr. Watts worked for George. Keith
Metalmelter
12-14-2011, 06:16 AM
Already covered here:
http://bbs.homeshopmachinist.net/showthread.php?t=50217&highlight=Square+Hole+Drill-bit
But yes I want one too;)
J. Randall
12-15-2011, 12:38 AM
JL.................
Used to be anytime this subject came up the guy from Slater tools showed up hawking his wares, but I have not seen an appearance from him in a long time.
James
johnnyd
12-16-2011, 09:05 PM
Here is a link to the online manual....
http://metalworking.com/dropbox/Watts_Bros_manual.pdf
