View Full Version : How to make LINK; 2 FLAT wshrs, either End?
abi456
01-12-2012, 09:18 PM
(o)-------(o) ??
Don Young
01-12-2012, 09:38 PM
Without more specific information I would suggest welding washers to the link or forging the ends of the link flat and then drilling holes. If you want to machine it from a solid piece, turn the link to the desired size, mill the ends flat as desired and drill holes.
fciron
01-12-2012, 11:04 PM
How many? How big? Material? How long a link? What kind of tolerance? What equipment do you have available?
Since you say 'washer' I am going to assume flat sheet. In industry a part like this would be made by punching it out with a press. If you need a single one for a repair you could drill two holes and then cut/file the outside profile.
abi456
01-12-2012, 11:16 PM
Don Young;
Thank you for the reply!
Gave some ideas to consider ... I need to get busy ...
