View Full Version : Latex Paint Removal
Horst
01-19-2012, 11:28 AM
Is there a solvent or stripper to remove latex paint from wood?
daveo
01-19-2012, 11:33 AM
Heat gun...
lakeside53
01-19-2012, 11:39 AM
Latex on wood? Many strippers... almost all of them. But what is your aim? Do you want a clean "wood-like" surface, or just to repaint? If the former, you will need to scrape and sand after the intial paint removal and the surface dries... a lot.
Horst
01-19-2012, 12:20 PM
the Jasco stripper I have does nothing, maybe it's old. I want to repaint with gloss enamel. Thanks
lakeside53
01-19-2012, 09:07 PM
Hmmm... are you sure it's latex then and not some epoxy paint? Jasco shreds latex.
Fasttrack
01-19-2012, 09:43 PM
Yep ... pretty much any paint stripper will pop latex paint off in no time flat.
Try HT-350 stripper. It is supposed to be safe for wood and it will strip urethane and epoxy paints.
http://www.hydroclean.com/data_sheets/ht-350.htm
Jpfalt
01-19-2012, 09:47 PM
Tolulene removes latex fairly fast. It's the main active ingredient in Goof-Off.
