i hope this doesnt sound to hokkey....but is it possible to turn ID of semi hard rubber tubbing..........just askin......Larry
rubber
I was gonna ask a similar question about machining a counter sink for a bolt/washer in a hockey puck on a lathe..I can do it with my drill press but would probably get better results on my lathe..The part i wasnt unsure of was whether the material being a rubber would grab too hard on the tool/tool holder..Flexing may be more problematic with turning your tubing..Last edited by Toxic; 01-19-2012, 01:30 PM.
Originally posted by chevy3755i hope this doesnt sound to hokkey....but is it possible to turn ID of semi hard rubber tubbing..........just askin......Larry
Just depends......sharp tooling, hardness of rubber, workholding, etc, etc.
Freezing does help. Grinding can be better, if the work allows.
