View Full Version : Craftex Lathe 9"x19"
M.I. Twice
01-22-2012, 01:57 PM
My question is can I replace the ball bearing clutch (five small ball spring loaded into five little dimples ) with a shear pin some thing like the shear pin on the small out board motors. IT has not been the best lathe but maybe someone can help me with an improvement to my problem. Regards.
loose nut
01-22-2012, 02:20 PM
The slip clutch on those 9" lathe are crap. I accidentally dropped some crazy glue in mine, locking it up solid and it has been great ever since.
M.I. Twice
01-23-2012, 08:07 PM
Loose Nut
Thank you for your reply
M.I. Twice
Tony Ennis
01-23-2012, 08:48 PM
I believe a shear pin is a common mod. There are all sorts of mods for that lathe on the innertubes.
bob_s
01-23-2012, 10:29 PM
Check out the 9X20lathe group on YAHOO.
They have a rebuild manual for these series of lathes that will cover the upgrading of the clutch.
