ironmonger
01-27-2012, 11:36 AM
I have an Electrocraft E19-2 servo motor that has a tach drive. I want to fit an encoder to the tach end, but the shaft size is 1/2".
I am planning on turning the shaft down to .250" and fitting a CUI to that end of the housing, but I am not quite sure how to remove the tachometer armature.
It appears that armature is just pressed on and can be removed with a suitable puller. I don't care what happens to the tach armature, but I don't want to damage anything else.
Am I on the right track to tach removal?
Thanks
paul
Thanks
paul
