scmw
02-22-2012, 11:20 AM
Hi Guys,
Of course, it always happens at the end of a project with one last series of parts to make. One of my Bridgeport Series II NC's (I have two identical units) is having a problem starting. Both run Mach 3. This mill was running at about 1200 RPM on the spindle and I started dropping the speed as I'm cutting some thin styrene plastic. Unfortunately the spindle slowed down and froze. I've tried to restart it but just get the three phase hum for a few seconds before I shut it off. I am going to try loosening the belt to see if it's a mechanical problem or if the motor might have finally given up the ghost. This particular unit is from the 1970's.
Has anyone else had a similar situation? If so, how did you go about fixing it? If the motor did die, would this be a situation where a VFD could be put in it's place? Both mills have 4HP GE motors.
Thanks,
Thanks,
