View Full Version : cam programs and holes?
i have some cad /cam programs ,( older ones) just wondering is there any that will use a g2 /g3 type code for round holes and shapes ... that dont cost alot ?. the programs i have just do lines or radial or spiral for the whole thing . bobcad21 is a program i have but never use for that reason .aswell as some cheap cadcam programs . ( ive only been doing cnc for 7 months so lots i dont know)
i have writen out all my codes by hand for almost everthing( except engraving) for the past 6 month
i hate the idea of haveing 100000-200000+ lines of code (and does a poor job) for a project that takes 100lines of code when i write it out and it always looks nice .
i dont make anything really complex , gun barrel bands ,sights , and simple 3d parts . i figure a program should figure holes and curves out .
any suggestion ?
macona
03-01-2012, 07:24 PM
Bobcad does not use g2 and g3?
Try cut2d
pressurerelief
03-01-2012, 08:23 PM
I use VCarve Pro, the big brother I guess of cut 2D. Simple enough that I could produce GCode within an hour of installing it. Kind of like an iphone, it works logically and is simple to use.
SkyMoCo
03-01-2012, 09:42 PM
I use SheetCam, it can do anything those more expensive CAM programs can do and more.
Most any of them will give you a free download where you can try it out.
v carve . sheet cam ?? do they actully do circles or is it all the same old back and forth / up and down .
i have bobcad 21 but never tried 2d cut ... should it do circular cuts ?
Steve Seebold
03-03-2012, 09:44 AM
I have BobCad 23, and it too is a real piece of crap, so I'm stuck using the GibbsCam I bought when I had my shop.
RayMJr
05-26-2012, 11:05 AM
I use BobCad v23 & v24.
My controller is EMC2 (LinuxCNC).
I needed to go into the post processor and customize it to work correctly with the controller. In doing so, I learned allot about how the process works, and am now able to quickly troubleshoot problems when they occur.
Before EMC2, I was using a Bandit controller (mid 1970's era), which the post processor from BobCAD was very simple (used very few g-codes), so most of my education was on modifying it to use more of the available commands on the Bandit.
Ray
isaac338
01-06-2013, 11:41 PM
Bobcad uses g2/g3 on my machine - you're likely using the wrong post.
robosilo
01-07-2013, 01:02 AM
Bobcad does G2 and G3. It doesn't always use it though when doing 3D roughing. But for cutting circles and 2D contours it uses G2/G3.
I use Bobcad and am happy enough with it. Is it the best? No. Is it affordable? yes. Does it get the job done? yes. But so do many other
CAD/CAMS. Spending the time to set the post processor to work for your machine can sometimes be a daunting task. As can learning new software. So download some demos, watch some youtube reviews/demos and inquire to the software companies and see what their software can do you you. Make them work for your money instead of just taking it.
ive actully got bobcad v24 , a much much better layout and result then the v19 .the v24 3d does exactly what i was looking for . every so often it messes up a lil ... but that could be me since im pretty new . im trying to find some mastercad,cam x4 and learn it but seems bobadv24 is almost as easy as it gets .
