View Full Version : Re-Tram Rigid Head Mill
Sierevello
03-09-2012, 09:13 PM
I have a Lagun FTV2 fixed head on my CNC mill with Anilam Crusader M control. It is indexed to the machine with two pins and slips into a boss in the machine casting and bolts on with 4-3/4" bolts. When I moved in the machine I had to remove the head from the machine to get it into the shop. I have it ready to run and am going to check the tram tomorrow.
Just in case it is out of tram I wanted to get opinions on what I should do to get it back in tram. Clearly it is fixed so I have very limited options, but I wanted to get some advice none the less.
macona
03-09-2012, 09:15 PM
It will be in tram. The only way to do anything about it would be to scrape the mating surfaces.
